Hi, I stumbled across this forum and was hoping to get some general advice on this set up.
I have a basement family room I want to install some ceiling and in wall speakers. The goal is to have everything hidden, no free standing speakers and on a budget.
The set up I'd go for is something like these polk 8" ceiling and wall speakers, and I would have a sub behind the couch (wireless with a sound bar), - sound bar as a center speaker, as well as acting as the front left and right speakers. The ceiling speakers would be positioned on the left and right of the couch, slightly in front of the couch. The in wall speakers would be ear level behind the couch.
Would this be a good set up? The room is rectangle and I'll be using the short side of the shape, right in the center. The room width is 10', all speakers I'll be able to get equal distance of 60" (5 Feet).
Questions I'm not sure if
- Will the sound bar be sufficient to provide center, front left and right
- Will the in wall rear speakers be ok pointing straight out from the back wall, or would you suggest angling them in (i'd build a custom wood box that angles them in slightly, this will go against my design of keeping everything hidden and discrete.
- The speakers have adjustable directional tweeters
- Having the speakers in the ceiling (using the directional tweeters) will this be ok pointing straight down?
- Will 16g wire be ok (only running 20 -40 foot max per speaker
- Polk Audio RC80i 2-way Premium In-Ceiling 8"
- Polk Audio RC85i 2-way Premium In-Wall 8"
- 89 DB per speaker, 20-100 wrms , 8 ohm
- I'll buy a basic receiver for about $250
- Decent $200 sound bar w/wireless sub
