Ceiling Pant... should I paint it black???
Discussion in 'Home Theater Projects' started by tonyGar, Mar 7, 2006.
  1. tonyGar
    tonyGar Agent
    Jan 2, 2006
    35
    I am painting the ceiling a light blue gray but I have heard its best to paint it black.....any thoughts???
    Pros and cons?
  2. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    It depends on what your display is. If it's a projector, flat black is best. Otherwise it doesn't matter.
  3. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    If you have a false ceiling with tiles don't paint them...I went down that path and those things are sponges and suck up paint like you wouldn't believe...it would have been cheaper to just buy black tiles and replace the old ones. Having a dark ceiling does help with projectors though as it cuts down on the reflections
  4. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    I'm assuming this is for a projector installation? If so, yeah, flat black. Walls dark, too...anything that could reflect light back to the screen.
  5. David Noll
    David Noll Stunt Coordinator
    Aug 31, 2004
    228
  6. Glenise
    Glenise Supporting Actor
    Feb 5, 2001
    773
    2
    I think black looks sexy but then I guess it depends on your room colors and other accents.
  7. Jay Mitchosky
    Jay Mitchosky Producer
    Sep 6, 1998
    3,729
    Ideally yes but aesthetically you might not like it. Darker is definitely be better. My ceiling is a darkish gray but in retrospect I have would have gone darker (still may in the future, although much more of a pain now that the room is finished).
  8. GregDas
    GregDas Auditioning
    Feb 28, 2006
    13
    I'll throw in as well for the "darker is better"...
    But you can also think color as well. For me a dark blue (flat) ceiling and dark purple (flat) for the walls was the ticket.
    Greg
  9. Kevin Magee
    Kevin Magee Agent
    Aug 26, 2000
    44
    Believe it or not the ceiling looks really good painted black. I used Bone Black, I believe a Ralph Lauren color. to paint mine in a flat finish. Some blacks are "blacker"
    than others. I thought my wife was going to hate it and warned her. She let me do it. Surprise, it turned out great and is real cool. She loves it and says it is an improvement in the room.
  10. Kevin Magee
    Kevin Magee Agent
    Aug 26, 2000
    44
    My cieling was gray at first. The black was an improvement over the gray.
  11. Don.l
    Don.l Stunt Coordinator
    Apr 9, 2005
    120
    I'm in the same boat. I'll be putting up the suspended ceiling soon, and will probably choose black. I don't really want black, but I know it will be the best choice and will probably look great.
    Don
  12. Derek1
    Derek1 Agent
    Feb 7, 1999
    26
    Black is absolutely the best choice for the ceiling color in a projector based home theater. Keep in mind that this is for several reasons.
    1. reduces the appearance of reflected light and light "halo" around the projector and down the light path to the screen.
    2. greatly reduces color shift at the screen. (light reflected off nearby surfaces will tint the image on screen to whatever color the neighboring surface is. Holding a bright colored object near a white wall is a fairly good demonstration of this undesired effect. Notice how the "white" surface becomes tinted. BTW there is a whole section on this topic discussed at Stewart Filmscreen training.
    3. It will piss of the interior decorator! (worth it every time)
    Derek
