Ceiling mount the Panny AE900
Discussion in 'Displays' started by Rick Westfall, Jul 17, 2006.
  1. Rick Westfall
    Rick Westfall Stunt Coordinator
    Dec 8, 1998
    220
    If you have a Panny AE900 and you hung it from the ceiling, I need to bounce some ideas off of you. In an effort to avoid keystone correction, I need to decide how far the projector needs to hang from the ceiling. My HT room is 12' wide by 17' deep with a 10' ceiling. I'm wanting to use a 100" screen and mount the projector about 14' away. Given the vertical lens shift, how far do I need to drop the projector? Also, assuming I'm supposed to hang the screen so that my eyes are lined up 1/3 the screen height from the bottom so the top of the screen would be ~90" off the floor.
    My brain is starting to hurt.
    Rick
  2. Rick Westfall
    Dec 8, 1998
    220
    Administrator..you can close this thread...I figured it out.
    Rick
