Ceiling FP mount & ceiling tile
Discussion in 'Home Theater Projects' started by Jim Mcc, Mar 21, 2004.
  1. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Hello, how have you guys with ceiling mounted front projectors and "Ceiling Max" ceiling tile system handled the transition thru the tile? Did you just cut a hole in tile for mount to come thru and replace tile? Or die you replace tile with something that could be removed easier, without removing all the tiles back to closest wall? I want to have easy access down the road for cables I will rough-in in ceiling conduit. In case you are not familiar with "Ceiling Max", it mounts tight up against ceiling joists, so you cannot just remove a ceiling tile anywhere right away. Thanks.
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I had something similar to this setup in my preious home. I made a hole through the tile and passed the mount through it. I also cut the tile in half so that I could remoe the entire tile from the area if I needed to.
