Cd/Sacd changer question
Discussion in 'Archived Threads 2001-2004' started by WarrenCo, Sep 11, 2002.
  1. WarrenCo
    WarrenCo Agent
    May 22, 2002
    31
    Is it harmful to leave my new sony 555 changer on at all times? What about on pause for long periods of time?
    My RDC-7 pre does not have any switched inputs (or any for that matter) so my 555 does not turn on when I turn on my system. There is way to turn the unit on from the remote. Anybody know if there is a discreet code for the Pronto?
    I appreciate any insight you could give.
    Thanx
    Warren
  2. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
    leaving it on is ok, but on pause is not good.
    -rob
  3. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Warren, as Rob said, you can leave the 'C555ES turned on, but I would not leave it in pause mode for extended periods of time.
  4. WarrenCo
    WarrenCo Agent
    May 22, 2002
    31
    Thanx guys. Thats what my instinct told me, but thought it best to ask. I am guessing while in pause mode the cd is actually spinning and eventually the motor will wear out?
    Warren
  5. David Berry
    David Berry Stunt Coordinator
    May 9, 2002
    150
    Although I do not leave the C555ES player on pause for an unreasonable amount of time, does anyone know what is happening inside the unit that might be causing harm?
  6. AaronD
    AaronD Stunt Coordinator
    Dec 4, 2001
    234
    David,
    I would think that it would be the mechanical wear and tear, when you pause a CD it usually stays spinning in the drive mechanism.
    If you forget once in a while it's not going to ruin your player, but if you continually do this it will affect the life time. Since it's an ES player you're well protected by that five year warranty anyway..
