CD-RW possible on Pentium?
Discussion in 'Archived Threads 2001-2004' started by Ian Ramos, Nov 22, 2002.
  1. Ian Ramos
    Ian Ramos Agent
    Apr 9, 2002
    46
    I have an old P233 MMX as a second PC in the house and wanted to get a CD-RW drive. I'm looking at getting a 12x8x32 drive. I know it's not possible to get it burning at 12x, but would it work if I tried it at a lower speed? I'm planning on replacing the PC soon, but if I can get a burner running on it, I won't have a buy one with the new PC.
  2. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    I had a P166 with a Mitsumi 4x4x24x CD burner for about 2 years, and it worked fine... So if you burned at lower speed, you prolly could get it to work
  3. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    You can buy a current drive for about $70CAN(32/10/40). Why would you get an old one??
    So if you upgrade your CDR will be the weakpoint.
    Brent
  4. Ian Ramos
    Ian Ramos Agent
    Apr 9, 2002
    46
    thanks nick.
    brent, I was looking to replace the DVD drive in the pc as well, and an LG combo drive caught my eye. also, the case only allows for 2 5.5" drives and the HD is already taking up one.
  5. Josh Lowe
    Josh Lowe Screenwriter
    Jun 19, 2002
    1,063
    it should work OK, i had a pentium 166mmx and later 233mmx that i used with my first burner, a 2x SCSI-based RICOH.
  6. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    ditto that. i had a 266mmx and my old burner worked good enough. i think it maxed out about 4x and i had to try not to use other app's while it was burning, but it definitely worked fine. my compilations were perfect...no funky blips or anything.
  7. Graeme Clark
    Graeme Clark Cinematographer
    Jan 5, 2000
    2,180
    I first RW drive was on a P100 and I didn't have much trouble with the RW part (burning CDRs was another matter, but I think I had a faulty drive for awhile)
    One of my previous jobs involved burning CDs on 486s (at 1x) which usually went alright.
  8. Ian Ramos
    Ian Ramos Agent
    Apr 9, 2002
    46
    thanks for your input guys.
