cd player under receiver?
Discussion in 'Archived Threads 2001-2004' started by Phil_O, Jan 28, 2003.
  1. Phil_O
    Phil_O Stunt Coordinator
    Feb 10, 2002
    135
    I've read on other forums about putting something heavy on top of your CD player to reduce vibration errors. I wonder if putting your receiver on top of it would be a good idea. It would be a convenient place for me b/c of space issues and possible sonic value (?). Is a receiver *too* heavy?
  2. Iver
    Iver Second Unit
    Sep 23, 2002
    324
    Structurally, it depends on how sturdy your CD player is. There are some flagship A/V receivers that could probably crush one or two of the lighter, entry-level CD players[​IMG]
    Other than that, your biggest problem would probably be heat. Receivers can throw off quite a bit of it. This might damage your CD player. Also, the lack of air circulation to the bottom of the receiver would likely be detrimental.
  3. AaronBatiuk
    AaronBatiuk Second Unit
    Aug 23, 2002
    333
