CD cleaners
Discussion in 'Archived Threads 2001-2004' started by Lewis, Aug 8, 2001.
  1. Lewis
    Lewis Agent
    Jul 6, 1999
    28
    I have a boom box that starts to play and then stops working. Is a CD cleaner worth trying. The box was stored in a garage for several months. It could also just be broken.
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i don't think it would hurt. i've used them sparingly in my car, pc & cd player with no harm...that i'm aware of.
    You step in the stream,
    But the water has moved on.
    This page is not here.
    [Edited last by Ted Lee on August 08, 2001 at 04:36 PM]
  3. David Susilo
    David Susilo Screenwriter
    May 8, 1999
    1,197
    It won't damage your laser head if you use the decent ones (Maxell, Allsop, etc). However, don't use the wet/dry type.
    I've used it in more than 500 drives with no ill effect.
