CD Changer recommendations -- must have a COAX digital output
Discussion in 'Playback Devices' started by Greg S, Mar 31, 2004.
  1. Greg S
    Greg S Supporting Actor
    Mar 13, 2000
    976
    Minimum of 5 discs but prefer larger capacity. The only major requirement is that it has a COAX digital output.
    SACD would be nice but not 100% necessary.
    Thanks for any and all recommendations.
    Greg
  2. glenn.arsenault
    glenn.arsenault Stunt Coordinator
    Feb 5, 2003
    60
    budget?
  3. Greg S
    Mar 13, 2000
    976
    At least under $500
    Greg
  4. Rick_Brown
    Rick_Brown Second Unit
    Oct 25, 2001
    449
    Harmon Kardon had a good one with a good chip and also HDCD.
  5. Rich X
    Rich X Stunt Coordinator
    Jun 18, 2002
    115
    I have a Pioneer Elite. Can't remember the model #. It has Coax out. I use the digital out to my pre/pro so I can't comment on the DAC's in the changer, but it sounds very good the way I use it. It was around $450 new.
  6. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    SCD-222ES. Can be found for right around $300 used. The 555 is in the $500-600 range. Both are great redbook players and very good SACD players.
  7. glenn.arsenault
    Feb 5, 2003
    60
    I have 2 changers, one is probably the best changer made (sound quality), it is a CAL Audio CL-10. That piece of equipment resides in my 2-channel setup. It has a digital output, but also has great DAC's in it so, I always use the analog outputs on it. You may be able to pick one up used for around $500. I also just picked up an Integra CDC 3.4 which so far seems like a good player. It also has a coax digital out. They can be had for under $300.
