Chris-C
- Dec 7, 1998
Hi Gang;
I know I did this to myself for buying a cheap external burner($80),but I need your help.
The unit (Philips CDRW400) is hooked to my laptop via a USB plug.
The burner plays a prerecorded cd when it's got one in it,BUT when I put a blank recordable CDR or CDRW in the burner,and a cd in my laptop to simply copy-I get a message that "there is no CD Recorder connected)!!!!!!!
It will play but not record (send but not receieve data).
Any ideas?
The USB cable attaches to the burner via firewire (1394).
The CD recording software is made by Adaptec,and it loaded ok.
The USB cable came with a floppy driver,and it seemed to load ok too.
It shouldn't be this complicated,but i'm not the greatest with puter's.
Chris
Any ideas?
Chris
