Cathedral Ceiling Speaker Placement
Discussion in 'Home Theater Projects' started by NickDiCe, May 15, 2006.
  1. NickDiCe
    NickDiCe Auditioning
    May 12, 2006
    4
    I have added a 24 X 24 family room addition with a 16' Cathedral Ceiling with 7/12 interior pitch. I am debating on installing my surround speakers in the ceiling above my listening area and the rear speakers in the wall behind my listening area.
    My question is should I just skip the surround speakers (which would be aproximately 12 feet above the listening area) and go with a vanilla 5.1 setup rather than trying to accomodate the 7.1 Format?
    FYI the front speakers will be in the custom designed cabinet I am having built to house my seperates and the 60 inch lcd rear projection tv.
    Thanks in advance.
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    32
    Katy, TX
    Wayne
    Whether or not you can benefit from a 7.1 set-up depends on your room and how it is laid out. They work best in larger rooms where the seating is a good distance from the rear wall. If you have your seating up against or near a back wall, you don’t really need a 7.1.
    Wayne A. Pflughaupt
  3. NickDiCe
    May 12, 2006
    4
    Thanks. My seating will be a good 4-6 feet from the rear wall. The problem is the ceiling directly above the rear of the seating area is about 10-12 feet high. I was thinking about using a Speakercraft AIM product for the the surrounds. Any thoughts?
