Chris Sigua
- Feb 16, 2001
I'm doing some remodeling so I'm planning to run some cables in the walls. I'm home running them ( 6 cable runs)to a closet. My question are:
1. Since I will be splitting the cable signal, do I need an amplifier? The longest run is probably 35 ft.
2. For Cat 5, I will be running these the same way as the RG-6 (6 cable runs) for computer and phone use. How do I merge the phone lines? Do I also use a splitter or distribution panel (this is only one phone number, so it will ring all the phones at once)?
Any suggestions, advice would be great.
Chris
Chris
