"Cast Away" correct aspect ratio?
Discussion in 'DVD' started by JamesCB, Apr 22, 2004.
  1. JamesCB
    JamesCB Second Unit
    Feb 20, 2003
    440
    About a year ago I accidently purchased the single disc, full screen version of Cast Away. Yesterday I was in a used CD/DVD store and saw they had both the single-disc and two-disc widescreen versions of this film. I traded my copy for the two-disc widscreen and am happy.
    But, I noticed some thing strange. The single-disc widescreen version had an anamorphic presentation of 1.78:1 while the two-disc version was anamorphic 2.35:1. Why would there be a different aspect ratio of the same film? Why would a two-disc special edition have a wider aspect? I thought the aspect ratio was determined by the direcor. Would you be losing some of the picture in the 1.78:1 version? What aspect is your version? Just thought it was strange to see different widescreen aspects of the same film. Any input on this topic will be appreciated.
    Thanx,
    James
  2. Bryan Tuck
    Bryan Tuck Screenwriter
    Jan 16, 2002
    1,729
    251
    1,610
    Bryan Tuck
    I don't have the DVD, but I saw (and ran) the film in theaters, and it was 1.85:1. I imagine the "2.35:1" label is probably a misprint. It happens from time to time.
  3. Danny Beck
    Danny Beck Stunt Coordinator
    Jan 14, 2004
    164
    I have the 2-disc version and I could almost swear that it's 2:35.
    I would say i'm about 98% sure that my copy is 2:35.
  4. RobertR
    RobertR Lead Actor
    Dec 19, 1998
    9,996
    366
    9,110
  5. Mark Bendiksen
    Mark Bendiksen Screenwriter
    Mar 16, 1999
    1,090
    I own the 2-disk set and I've watched it multiple times. I'm 100% certain it's 1.85:1 aspect ratio. [​IMG]
    If you saw 2.35:1 anywhere then it was a misprint.
  6. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
  7. RodneyT
    RodneyT Stunt Coordinator
    Nov 17, 2003
    138
    is this the same kind of misprint that had the original Aliens DVD release labelled as 2.35:1 and caused lots of my customers to come back complaining that they had a fullscreen version of the film? This is basic, common sense people. Why can't studios get this kind of technical stuff right?
  8. JamesCB
    JamesCB Second Unit
    Feb 20, 2003
    440
    Thanks for the replies. I put the movie in last night, it fills the entire screen of my 16:9 tv. The box does say 2.35:1, so it is obviously a misprint. BTW it is 1.78:1 and not 1.85:1. If it were 1.85:1, I'd have black bars at the top and bottom of the screen. Thanks again for the replies.
    James
  9. Roger_R
    Roger_R Second Unit
    Nov 6, 2003
    372
    Actually, those black bars are not noticable on most TVs because TVs have something called overscan. It means that parts of the picture are outside of the 16x9 area that you can see. TV-manufacturers do this because one of the first things to deteriorate on a TV are the edges of the tube, so they black it out.
    Try to play it on a PC, and you should see some small, black bars at the top and bottom.
