Grant B
- Mar 29, 2000
A few years back I converted all my tapes to cd and a friend was thinking about buying the dual deck which is a Sony ES model.
I let him take it home and test it out and he said it started to screach pretty loud.
I was thinking that it might be the lub that dried out and it seems pretty easy to clean up and put some new lube on.
Anyone know if this is usually an easy thing to correct?
I doubt if most places would fix it cheap or at least cheaper than what I would see it for.
Grant
Grant
