Mike.Thompson
Grip
- Dec 5, 2002
Hello-
I just bought a Carver amp model TFM-24. This is essentially the same as the TFM-25, sans the VU meters and replaced with LED's. The problem I am having is the distortion put out- the best way to describe the sound is like a bad radio signal. I have tried cleaning the binding posts somewhat, tried multiple pairs of interconnects, and speaker wire as well. What happens is I turn it on, it sounds bad, and if I turn it up much either the amp or pre-amp goes into protection. The pre-amp I am using I believe works fine because headphones work like a charm., model CT-6. If anyone has had a similar problem, has a place for me to start or anyhting I would be most appreciative as I am pretty clueless and lost but need to enjoy my tunes!
Thanks in advance. Mike
