Cardboard Port???
Discussion in 'Archived Threads 2001-2004' started by Frank Kanyak, Apr 2, 2002.
  1. Frank Kanyak
    Frank Kanyak Stunt Coordinator
    Feb 28, 2002
    240
    I have at my disposal a 7" diameter cardboard tube with the edges being 1/2 think making it 6" inner diameter. Can I use this for my 26"port??? Or should I go with a PVC???
  2. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,763
    486
    9,110
    As long as you seal it well where it mates with the endcap, this should be okay. Many speaker makers use cardboard tubes for their ports (but they usually have a nice plastic flared piece on the outside of the endcap/side to hide that fact).
    In fact, I used a Quikrete 8" wide tube for the port on my Sunosub I.
  3. Frank Kanyak
    Feb 28, 2002
    240
    Even though it is 1/2 thick? If so, great!!! I'm going to use the Grizzly Glue and maybe use (3) small "l" type braces to secure endcap to port with 3/4 particle screws. Great I just saved $15.
  4. Patrick Sun
    Jun 30, 1999
    38,763
    486
    9,110
    A tube's a tube. As long as it's functional, use it.
    And sonotube's thickness is around 1/4", and it'll be fine to use. Remember this stuff is used to form concrete structures, so it's strong.
  5. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    I have used a 8" sonotube for a port before and it works just fine. Like Pat says, "A tube's a tube."
    Kyle Richardson
    Acoustic Visions
