Car Subs for home theater... will it sound good ?
Discussion in 'Archived Threads 2001-2004' started by Tyler, May 20, 2001.
  1. Tyler
    Tyler Stunt Coordinator
    May 8, 2001
    112
    Hello i want to build my own subwoofer and i would like to know if fairly good car subs would work & sound good for Home Theater in my house.
    I know that you have to use a 4 ohm amp on car subs.
    But will this work ?
    P.S my room size is about 19 feet by 16 feet with a 8 foot celing.
    Thanks for any input
  2. Dustin Haug
    Dustin Haug Agent
    Jan 6, 2001
    35
    Car subs will work just fine for a home sub. And you don't need to use a "4 ohm amp" (assuming you mean stable at 4 ohms) to drive all car subs only 4 ohm car subs. Many car subs are 2,6, or even 8 ohms per coil. Just make sure that whatever amp you drive the sub with is stable to at least the impedance of the speaker you're using.
    i.e. if you have a single 4 ohm speaker make sure your amp is stable to 4 or even 2 ohms mono.
    My DIY sub page
  3. Julian Data
    Julian Data Second Unit
    Oct 5, 1999
    408
    Most car subs would work well. Just keep an eye on the OHMs they use.
  4. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Just keep in mind most car subs aren't going to have the same Xmax as those Mass 2012's! [​IMG]
    Brian
  5. Julian Data
    Oct 5, 1999
    408
    Oh how so true!
    Those DD subs looks interesting. [​IMG]
    hehe.
