RayJK
- Nov 25, 2002
I ran across this in my wanderings over the net. http://www.thezeb.com/caraudio/audiobahn_specials.html
Specs are:
AW1805X
Fs 21.9 Hz
Qts 0.41
Qes 0.44
Qms 5.4
Vas 142 Liters
Vas 5.0 Cu. Ft.
Re 3.15 ohms
Le 1.95 mH
Xmax +/-25
Pmax 1200 watts
EBP 50
Freq. Resp. 16Hz-500Hz
Efficiency 97 dB
Dimensions:
Depth 7 3/4"
Hole 16 3/4"
Diameter 18 1/2"
I can get it to match the Tumult almost exactly in a 160L smaller box according to WinISD. At $250 it ain't bad.
Specs are:
AW1805X
Fs 21.9 Hz
Qts 0.41
Qes 0.44
Qms 5.4
Vas 142 Liters
Vas 5.0 Cu. Ft.
Re 3.15 ohms
Le 1.95 mH
Xmax +/-25
Pmax 1200 watts
EBP 50
Efficiency 97 dB
Dimensions:
Depth 7 3/4"
Hole 16 3/4"
Diameter 18 1/2"
