Todd Hochard
- Jan 24, 1999
Rapid changes in indicated temp can be due to a faulty gauge or temperature.
However, actual temp can also change like that. How so? If, for whatever reason, you are developing steam pockets in the cylinder head (which is where the sensor is), indicated temp can change rapidly. Steam pockets could be developing because:
1. Bad radiator cap.
2. Low coolant level.
3. water pump impeller is bad, and lacks sufficient pumping pressure.
4. Bad thermostat, causing localized boiling in the head.
5. System overheating, due to radiator clog or fan not working, in conjunction with older/worn parts in other parts of the cooling system, can cause this as well.
The rapid up-down is the formation, and subsequent collapse of the steam bubble.
Good luck. Remind your technician- an important rule of troubleshooting is, "Believe your indications." In order to accurately get to the bottom of the problem, take what you see at face value, until you can prove that the indication is not valid.
Todd
Todd
