Car audio help needed! GR 6.5" woofers ok?
Discussion in 'Home Theater Projects' started by bruin, Jul 5, 2003.
  1. bruin
    bruin Second Unit
    Nov 29, 2002
    264
    Is there any restriction or negative effects of using a 6.5" GR woofer in a car audio application? I am planning to pair it with a VIFA 1" D25AC-05.
    -if anyone has any experience with car audio apps, how would I go about constructing a x-over?
  2. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    You might want to run it by Danny since it's his driver. He could steer you in the right direction. I do know that unless you're mounting them down in the kick panels that you're probably want to see how they perform very far off axis. If you're mounting them down in the doors then you will be at least 60 degrees off axis.
    Sorry I couldn't be of more help. There usually aren't much in the way of specs for car audio midbass drivers so I don't know how the specs of the GR driver compare to the average car audio midbass driver.
