www.caraudioforum.com
I've always had good luck with it, but the nature of the beast is you won't find a car audio forum as grown up as the HTF.
Since I have built my system completely, I haven't been there is about 6 months, but I got all of the recommendations and install advice from this site.
Search the topics, ask your questions, you'll be fine. Just remember you are dealing with a younger set than you are here.
Anthony-
The type of people that are into car audio are less likely to be intalligent.
KNA MEAN BOYYYYYYYYYYYYYYYYYYY?
Good luck finding a forum CLOSE to this out there
