Car A/C - Turn it off before shutting off the ignition ?
Discussion in 'Archived Threads 2001-2004' started by Kirk Gunn, Jul 29, 2002.
  1. Kirk Gunn
    Kirk Gunn Screenwriter
    Aug 16, 1999
    1,609
    My dad always said you should shut off the A/C a few minutes before the car. Something about it equalizing the pressure in the compressor, and the seals would last longer.
    Makes sense, but any truth to this ? Thanks
  2. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
    I fixed your thread title. Some typos can be a bit embarrassing. As originally written:
  3. Zen Butler
    Zen Butler Producer
    Jan 24, 2002
    5,548
    20
    6,610
    Southern, Ca
    Zen K. Butler
    In 20 years, I have never heard of this. I asked our Master Tech, he says definite false. sorry [​IMG]
    but I'm sure this just may spark debate
  4. Jared_B
    Jared_B Supporting Actor
    May 7, 2001
    580
    The only reason to do so is to prevent any musty smell upon startup. The condensor (i think that's what it is) in the AC system releases moisture when it's turned off. The moist air sits in the AC system until you start the car again, then it is blown into the cabin and usually stinks pretty bad. Turning off the AC before the car will allow this moist air to be circulated out of the system.
  5. Allen W
    Allen W Stunt Coordinator
    Dec 10, 2001
    62
    Well I have to say I am a big believer in turning off the AC button 30 seconds before the engine.
    I have a 1990 Chevrolet pickup that is now going through it's thirteenth Texas summer with the original A/C compressor. Somebody told me years ago to turn off the little AC button (I leave the fan on) about 100 yards before I parked the car. I just incorporated into my daily driving, it is 2nd nature now. I have not added freon to the system in 5 years, so obviously the seals are holding.
    Try this little test, on my car you can hear it easily. Turn off the key with the AC running and see if you hear a psssshhhh sound under the hood of the AC compressor releasing the pressure. Then try it again but turn off the A/C 30 seconds before you turn off the key. On my car it's quiet.
  6. Leila Dougan
    Leila Dougan Screenwriter
    Mar 27, 2002
    1,352
    I've heard the same thing Jared has. In addition to the musty smell, I also heard that if everything stays most it can start molding which I don't think is too great for the parts or your lungs.
  7. Ryan Wright
    Ryan Wright Screenwriter
    Jul 30, 2000
    1,875
    I turn it off just before I park so I can use that last bit of cold air for "free" and save the .00002 cents worth of gas it would cost to run the compressor for that long. [​IMG]
    I also don't like to start my car with the A/C on, so it always gets turned off while I'm parking.
  8. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
  9. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
  10. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
  11. BrianW
    BrianW Cinematographer
    Jan 30, 1999
    2,563
    38
    Brian
  12. Ken Garrison
    Ken Garrison Supporting Actor
    Jun 1, 2002
    543
    I have a 1984 Toyota Van and I wanna know how much it'll cost to have the pump replaced and have it converted to the new freon crap? Napa told me around $500-700 bucks. Maybe I can save labor by removing the passenger seat and the panel underneath it before I drive it up there. Engine's located under my ass. LOL So, if I disassemble it and make the access better, then the labor should be lower. Then I can put it back together when I get her home.
  13. Allen W
    Dec 10, 2001
    62
    Brian - how many years are we going to have to go till one breaks and we find out who the final winner is! I do feel like I have gotten my moneys worth on this car. I sure don't have enough of a control group to prove that my A/C wouldn't have lasted this long without turning off the switch, but I'm sticking with my plan. Also I don't know what a vacuum controlled A/C duct is, I have never had to fix an A/C before [​IMG] .
    Todd - probably true that the A/C makes noise when you turn it off with the engine running. I think it has more time to gradually release the pressure rather than all at once when you after you turn off the motor. This is just a theory of mine, I don't actually know how they really work!
  14. Darren Davis
    Darren Davis Stunt Coordinator
    Oct 9, 2001
    248
    Ken, my 89 Buick Skylark isn't blowing cold air right now and it seems to need more r12. Anyway, I just talked to my mechanic brother-in-law about the r12 to r34 conversion (via a kit) and it doesn't sound too promising. Everything in the A/C system needs to be sucked out because the refrigerant oil used for r12 isn't compatible with the r34 oil and when they mix a sludge is formed that clogs everything up causing the whole a/c system to not work. And, even after the conversion is done there's still no guarantee it'll work. He told me it's a "crap shoot." And, if it does work (and it can, my older brother told me he's done this to a few of his previously owned cars (GM)) the air might not run as cold as with the r12. Based on the lengthy discussion I had with the mechanic today I think I'll stick with the r12. At $70 a lb. it's not cheap but I think it's the safer way for me to go.
    Just my 2 shillings
  15. Ken Garrison
    Jun 1, 2002
    543
    Well, I'll have it converted and see if that works. If the R 12 worked so much better, it sucks that them environmental wackos switched to something different. Ozone depletion is a myth.
  16. Kirk Gunn
    Aug 16, 1999
    1,609
    Thanks folks ! And thanks for editing my Typo Michael !
  17. Todd Hochard
    Jan 24, 1999
    2,312
  18. Dan D.
    Dan D. Stunt Coordinator
    Aug 29, 1999
    215
    For all those unaware, another good a/c longevity tip is to run the compressor a few minutes at least once a month during the winter to keep the seals lubricated. Nine years on my '93 Civic Si and no recharges yet - still running cold.
  19. Carlo Medina
    Carlo Medina Executive Producer
    Oct 31, 1997
    10,642
    777
    9,110
    You know, I've never "heard" to do this or not to do this...
    It's just something I do anyway. Don't know why, it just seemed to make sense. Go figure...
  20. Ryan Wright
    Jul 30, 2000
    1,875
