Capture DVD image form a pc
Discussion in 'Archived Threads 2001-2004' started by John Masterson, Oct 19, 2002.
  1. John Masterson
    John Masterson Auditioning
    Jun 30, 1997
    3
    Hi
    Is there any software that will capture a still frame
    image from a dvd running on a PC.
    Thanks in advance
  2. Brice
    Brice Stunt Coordinator
    May 21, 2002
    104
    Cyberlink's Power DVD does...
  3. Walt Williams
    Jul 28, 2002
    19
    I'm using PowerDVD version 3.0 and screen captures work fine. There's a catch though - I installed a new ATI Radeon video card and PowerDVD won't recognize it. This means that I can't used the card's hardware decoder and DVD's don't play smoothly. I downloaded an update for PowerDVD so it would use the video card properly and realized that they had also deactivated the screen capture button when playing DVD's (VCD screen captures still work thought). I had to remove PowerDVD and re-install it from the CD to get the feature back. Now I use the software that came with the video card if I actually want to watch something, and PowerDVD is just for screen captures.
