Captions on Sony 35" KV-35XBR48
Discussion in 'Archived Threads 2001-2004' started by John B., Feb 2, 2003.
  1. John B.
    John B. Stunt Coordinator
    May 19, 1999
    54
    I have a 35" xbr Sony. It's probably about 4 yrs old. I used it w/ DirectTv, so the TV stays on ch. 3 all the time i think.
    I'm trying to figure out how to get the closed captioning (i.e. subtitles) to work....the menu system indicates that it supports close captioning, it even has 4 different ones - cc1/2/3/4...but i can't seem to get it to work on any channels.
    How do you get the captions? It's not a setting on my dss receiver is it? I thought the TV could do it. I know the TV's at the gym (and i assume those are dish of some type) have captioning on them, and those aren't xbr's.
    Thanks for any tips.
  2. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    Set it on CC1 then test it with your local stations. However, note that not all DirecTV channels use CC but most locals do.
  3. John B.
    May 19, 1999
    54
    I should add, that all the same stations they play at my gym where i see their captions, i've tried on my TV at home, and no luck.
    e.g. i'm watching Comedy Central's Man show now, and the channel info shows the 'CC' logo for this broadcast...my tv is on cc1, and there's no captions.
    Can anyone w/ DSS get captions? If so, how are you doing it...
  4. Reginald Trent
    Feb 18, 2000
    1,313
    How is your DTV reciever connected? RF or line inputs? I ask because perhaps your TV is only capable of displaying CC using only one of those connections not both.
  5. John B.
    May 19, 1999
    54
    Directivo dss receiver:
    * has RF out, that is connected to the VHF/UHF jack on back of TV
    * has Svideo out, that is connected to my receiver's TV/SAT svideo in jack
    My receiver:
    * has Monitor out svideo line, that is connected to Video 1 svideo input on the TV
    * has
    I normal watch the dish w/ the TV set on Video 1. Although I can also switch it off any of the video inputs and just use the normal one...this way looks the same...i see and hear the dish shows, but no captions.
  6. Reginald Trent
    Feb 18, 2000
    1,313
    Try viewing using channel 3 to monitor DirecTV programing. See if you can see CC using channe; 3.
  7. John B.
    May 19, 1999
    54
    well unfortunately that doesn't help. tv was already on channel 3. the tv has some feature called 'channel fix' and it's set to ch. 3 right now.
  8. Reginald Trent
    Feb 18, 2000
    1,313
    Tune to VH-1 335 and see if you get CC
