Can't uninstall Firefox....please help
Discussion in 'Computers' started by Alf S, Sep 19, 2004.
  1. Alf S
    Alf S Banned
    BANNED
    Apr 23, 2000
    3,477
    621
    4,110
    Alfer
    My Mozilla Firefox died this morning and I tried to uninstall it, but there is NO uninstall system and it isn't even in my ADD/REMOVE section.
    Any ideas how to completely delete it from my system?
    Using XP SP2
  2. ThomasC
    ThomasC Lead Actor
    Dec 15, 2001
    6,526
    Try to install it again and then uninstall it.
  3. Steve Berger
    Steve Berger Supporting Actor
    Sep 8, 2001
    975
    5
    110
    I don't think Firefox actually "installs" itself. It's just an executible that you run. Removing it involves deleting the files or directory. At least that is how Firebird (it's predecessor) behaves.
  4. ThomasC
    ThomasC Lead Actor
    Dec 15, 2001
    6,526
    Firefox is in my list of programs when I open up "Add or Remove Programs" in the Control Panel.
  5. Alf S
    Alf S Banned
    BANNED
    Apr 23, 2000
    3,477
    621
    4,110
    Alfer
    I bit the bullet and installed the latest Firefox and it now works and is finally listed in my ADD/REMOVE.
    Thanks for the input folks.
  6. Paul Bartlet
    Paul Bartlet Stunt Coordinator
    Dec 1, 2000
    88
    FireFox has both an installer, and one that you just extract and use. So you must have used that one that extracted only. Deleting it's directory (example C:FireFox), when this is deleted, it's completely gone.
    It's in I believe "all" of the Mozilla software "readme" files to remove old before installing newer version.
    Delete were you put FireFox, install or extract again and all should work again.
    Just in case, look into it's directory and find your bookmarks in there, copy them somewhere else. Then put them back when new is working.
    So if you end up getting the Extracting one again, just right click, and extract. Inside folder created, you'll find "FireFox.exe", double click and your browsing.
    Right click on that, and Create Shortcut, move Shortcut to your desktop and done.
