Can't save jpeg images.
Discussion in 'Computers' started by Kevin_Graham, Jun 21, 2006.
  1. Kevin_Graham
    Kevin_Graham Stunt Coordinator
    Mar 1, 2001
    131
    When I save a pic from a website, the saved icon appears as if it doesn't recognize the file type. If I click on the saved image, I get a window asking me what program I want to use to display it. How do I fix this so when I save a jpeg it remains a jpeg on my computer?
  2. Jeff_CusBlues
    Jeff_CusBlues Supporting Actor
    Jun 19, 2004
    605
    Sometimes, a pic downloaded as such has the extension .jpe instead of .jpg. I have found that some viewers do not recognize this extension. In your instance, If this is the case, rename the extension .jpg and you should be good to go.
  3. Parker Clack
    Jun 30, 1997
    12,220
    75
    9,110
    Kansas City, MO
    Parker
    What program are you using to view your images with? Do you have a program that can save one file type to another type? What extensions do the files have that you download? .gif, .jpg, etc? Do you tell your system what program you want to use to view the picture with when it asks you? Have you tired renaming the file when you download it say from xxx.jpg to yyy.jpg and see if you can view it then or are you saving it as it is named?
