Can't get ABC HD
Discussion in 'Playback Devices' started by Brian Osborne, Feb 3, 2006.
  1. Brian Osborne
    Brian Osborne Stunt Coordinator
    Sep 2, 2005
    215
    Help me...
    I live in central Iowa and I just recieved a set top box I bought on ebay. I am able to tune all of the DTV channels except for ABC. From what I see it should be 5.1 but I get no signal strength from that channel at all. My set top box is a Samsung SIR 151.
    Anyone help me with this mystery?
  2. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,882
    751
    9,110
    Since 2006
    Cameron Yee
    Have you been to antennaweb.org? I just punched in a zipcode for Des Moines and it shows the ABC as requiring a "Large, Directional with Pre-Amp" (violet code) antenna versus the others which need a "Small, multi-directional" (yellow code) antenna. That seems a bit odd, seeing most of the other stations are in the same location. Maybe the ABC station is broadcasting at low power?
  3. Charlie Campisi
    Charlie Campisi Screenwriter
    Aug 20, 2004
    1,624
    44
    1,610
    Is your STB automatically remapping 5.1 to the true UHF channel number? Look at the true channel number on antennaweb and see if you can tune it in that way.
