Anthony Stephan
- Mar 6, 2000
Just like every other piece in our HTs, the more you read, the more confused you get.
I'm looking at the Mits WS65819 and the Tosh 65HX81.
Both are nice sets, and both would be great after being tweaked.
I know that the Tosh sets look great right out of the box. It was even evident in the store.
I know that the Mits has a problem with Red push, that can be fixed. There have been horror stories with both brands. And there have been glowing reviews as well.
One problem I have is fitting the TV down the basement stairs. On that point the Mits wins because it can be broken down into two pieces. On the other hand, the Tosh will probably just fit. But what do I do when I need to bring it back up the stairs for the next upgrade?
Your opinions are welcome.
