Can't burn in iTunes - help!
Discussion in 'Music' started by MickeS, Nov 20, 2003.
  1. MickeS
    MickeS Producer
    Jul 24, 2000
    5,058
    I am trying to burn a CD in iTunes, that I purchased from iTMS.
    I have tried 5 times now, and I keep getting an error. The slower I burn, the earlier the error comes (when I burn at max speed (52x), it comes at the very last song, when I burn at 16x it comes in the beginning of the album).
    I have tried burning on other discs from the same spindle using Nero, and everything works fine there.
    This is really bumming me out, and I can't find any help anywhere. Does anyone have any suggestions for what to do?
  2. Shane D
    Shane D Supporting Actor
    Feb 12, 2001
    651
    what is the error saying?
  3. Anthony Hom
    Anthony Hom Supporting Actor
    Mar 24, 1999
    890
    I bought a pack of HP CD-RWs recently to use on my Yamaha 20-10-40 burner. It kept failing on every disk (25 pack) no matter what speed, gave up after disk #10 failed. Returned them all and bought Memorex CD-RWs, worked great absolutely no problems. I guess you can only use HP CD-RWs on HP burners, but they don't say that on the package.
  4. MickeS
    MickeS Producer
    Jul 24, 2000
    5,058
    Shane, just that there was an error burning, and that I should try a lower speed... not really specific. I've tried lower speeds, but it doesn't help.
    Anthony, were you trying to burn with iTunes when that happened?
    I just don't understand why iTunes would fail burning when Nero can burn. I didn't think the software made that much of a difference.
    Of course, considering it's an Apple program ported to Windows, maybe problems like this are to be expected...
  5. Patrick Larkin
    Patrick Larkin Screenwriter
    May 8, 2001
    1,759
  6. MickeS
    MickeS Producer
    Jul 24, 2000
    5,058
    Patrick, I looked at those already, but thank you anyway. I think advice #1 might be the best in this case, sadly... [​IMG]
    I haven't burned the playlist more than 10 times so I know that is not the problem (and it's an actual burning error, not a message saying I'm prevented from burning), but I was wondering about that statement, because it says in the iTunes marketing material that you can burn as many CDs as you like.
    Does it mean that I would have to rename the playlist, in the unlikely case I'd want to burn more than 10 copies? Or does it keep track of the song collection itself?
    I got a plug-in for Nero that lets it burn MPEG-4/AAC files to an Audio CD, I'm going to try that a little later. I'm assuming it won't work though, since Apple has DRM on the songs from iTMS.
  7. Garrett Lundy
    Garrett Lundy Producer
    Mar 5, 2002
    3,764
    Are you running iTunes on a PC or a Mac? My PC has trouble burning CD's especially if I have more than the burning program open.
  8. MickeS
    MickeS Producer
    Jul 24, 2000
    5,058
    Garret, I am running it on a PC, and after reading your post, I went in and shut off all non-essential running processes. That did it! It burned just fine. Thank you!
    What a hassle having to do that every time though... maybe they'll come out with an update soon that'll fix this.
  9. Anthony Hom
    Mar 24, 1999
    890
    MickeS - I use Roxio on both Mac and PC and they failed on both. The CD-RWs in question are all high speed 10x discs, and I even did a burn at 2x and it failed. I would have tried 1x, but whats the point? Would anyone here by a 25-pack of CDs only to have to burn them at 1X?
    Anyway, I bought other discs by Sony, Memorex and TDK and they have not failed, even after repeated burnings.
  10. Patrick Larkin
    May 8, 2001
    1,759
    I believe you need to change a playlist in some way to burn it for the 11th time. Rearranging a song or adding/removing a song should do it.
