Jon_Are
- Jun 25, 2001
I just upgraded to WindowsXP. I then installed Norton Internet Security, which seems to work OK with the exception of the Anti-Virus part; whenever I try to open the anti-virus, the program freezes.
So, I'll just uninstall it, then re-install, right?
Wrong. I am unable to uninstall NIS. I tried through the control panel using the 'remove programs' utility, and also through the Norton disc itself. Each time, it tells me that the Norton is running and to close all NIS windows.
I went through and disabled everything I could find, but I still get a message that the program is running.
When I do alt-cont-del, it shows no applications at all open (back when I was running Windows 98, doing this would show a list of 10-15 programs running...WTF?)
This is really irritating me. Before I take a 16 lb. sledge to the PC, anyone have any ideas?
Jon
Jon
