Cannot play internet versions of ota radio stations anymore, what happened?
Discussion in 'Computers' started by TonyD, Jul 11, 2006.
  1. TonyD
    TonyD Who do we think I am?
    Dec 1, 1999
    17,528
    578
    9,110
    Gulf Coast
    Tony D.
  2. Rommel_L
    Rommel_L Second Unit
    Apr 25, 2000
    355
    Clean temp internet folder of all cookies and file and close. Reopen and see what happens...
  3. TonyD
    Dec 1, 1999
    17,528
    578
    9,110
    Gulf Coast
    Tony D.
    nope. that isnt it.
  4. Rommel_L
    Apr 25, 2000
    355
    Does it work on IE? If it does, then just use IE. But before using IE, check this site on how to configure security settings and this site on how to configure privacy settings...
  5. TonyD
    Dec 1, 1999
    17,528
    578
    9,110
    Gulf Coast
    Tony D.
    nope not ir either.
    cant play sirius, xm nothing.
    i can use youtube and any other thing like it just no live type programming.
    i just see it loading then the little window says "ready" then nothing.
  6. Greg*go
    Greg*go Supporting Actor
    Jun 14, 2002
    941
    Since it doesn't work in IE either it seems a little confusing, but I figured I'd tell you this is a known issue with the lastest Firefox security update.. Did you just download Firefox 1.5.0.5 recently? If you go into Help -> About, you will see what version you have. You may want to read this thread over at Mozilla's forums.
    Firefox 1.5.0.6 coming soon (to fix streaming media)
    It mentions only certain streaming video as having problems, but there may be some issues with the certain audio files as well.
  7. TonyD
    Dec 1, 1999
    17,528
    578
    9,110
    Gulf Coast
    Tony D.
    it may have started right about when i moved to 1.5.
    but it shouldnt stop it from working in ie.
  8. Rommel_L
    Apr 25, 2000
    355
    When trying to access mentioned web sites in IE set the pop-up blocker to allow pop-ups...
  9. TonyD
    Dec 1, 1999
    17,528
    578
    9,110
    Gulf Coast
    Tony D.
    thanks for that idea rommel
    doesnt work.
    oddly tho'
    i can switch to a new "user" that i just created and i can get to the audio there.
    not on my main user
  10. Paul_Sjordal
    Paul_Sjordal Supporting Actor
    May 29, 2003
    831
    Then it must either be a setting or a permission issue (I was gonna suggest reinstalling drivers and codecs).
    Are you using a software firewall? If so, double check the permissions in your main account against the permissions in your new account.
