Cannot connect to xbox live
Discussion in 'Archived Threads 2001-2004' started by Zack_R, Nov 10, 2002.
  1. Zack_R
    Zack_R Stunt Coordinator
    Nov 4, 2002
    220
    I purchased the retail starter kit and it tells me that the DNS is not resolved. "The DNS servers could not be reached. Verify the DNS Server address match the settings provided by your ISP."
    I get this message whether I connect through the cable box directly or run it through the hub on the computer. My cable provider is insightbb.
    Any suggestions to resolve appreciated. How would I verify the DNS server address and the settings provided by my ISP?
  2. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    you might have to hard encode the MAC address into the Xbox. Someone else was having this issue and thats what he had to do.
  3. RayKk
    RayKk Stunt Coordinator
    May 4, 2002
    113
    Depending on ISP in many cases a router is best, SMC NetGear and Dlink have problems with Xbox there are work arounds posted and some routers just wont work, the linksys Cable/DSL router works great also the Microsoft routers work well, do you know how to release or renew your IP, I dont know how much you know if you can tell me I can walk you through the whole thing.
  4. Zack_R
    Nov 4, 2002
    220
    I'mot sure how to release or renew my IP. I'm not even sure where to go to find out that info. From reading other threads it seems like the router will be my best bet for least complicated gaming and internet setup.
  5. Travis Kolesar
    Travis Kolesar Second Unit
    May 16, 2002
    291
  6. RayKk
    May 4, 2002
    113
  7. Tom_J
    Tom_J Agent
    Oct 23, 2000
    26
    Zack_R, if you are using Win2k, open up a command prompt (Start->Run->cmd) then type in "ipconfig /all" (no quotation marks, of course). This will give you all the info your looking for, DNS, IP, etc.
    To release, renew, just type in "ipcofig /release" "ipconfig/renew" respectively. If in doubt, type in "ipconfig /?" for all the optional switches.
    Hope this helps.
    With that said, I have a Netgear RT314, and looking at xbox.com's workaround, they're simply giving the Xbox a static IP addy, then pointing the Xbox at the router. Sounds simple enough.
  8. Zack_R
    Nov 4, 2002
    220
    Thanks for the feedback.
    Tom,
    I have windows 98 and when I type those commands, they seem to work but the info. flashes on the screen so fast I don't have a chance to read it. Is there anyway to make the information screen stay up so I can read it? I'm not sure why it will not stay up. It looks like a dos screen that opens for less than a second and then disappears.
  9. Chris Rock
    Chris Rock Supporting Actor
    Jan 10, 2001
    710
    Zack,
    In Win 98, try typing winipcfg.
    It has buttons on it for release and renew.
  10. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
    Maybe I'm wrong, but won't those procedures simply release/renew the IP addressing on the PC you're executing the command on? I don't think it'll do a thing for the Xbox connected to the router...
    I would think you'd have to log into the router, execute a release/renew from the router level, and then re-detect the settings on the Xbox...
  11. Rusty Ray
    Rusty Ray Second Unit
    Jun 26, 1999
    273
