Canadian b5 question
Discussion in 'Archived Threads 2001-2004' started by Chris Purvis, Oct 31, 2002.
  1. Chris Purvis
    Chris Purvis Stunt Coordinator
    Dec 11, 2001
    151
    So a friend of mine at work here just realized that last night he ordered the Babylon 5 Season 1 disc from a Canadian dvd retailer (they had the lowest price - probably in because it was in Canadian dollars [​IMG] ). Anyway, now he is asking me if there's anything about it that won't work and I said Canada is region 1 so it should be fine, but it might have bi-lingual packaging. Is this the case? I know some Canadian releases are different then their US counterparts because of this but I'm not exactly sure what the rules are about it...
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    If it's from a major studio, usually the biggest part is that the packaging has French text as well. Since "Babylon 5" is pretty much the same in either language, I doubt they'll bother
  3. ChristianB
    ChristianB Stunt Coordinator
    Jan 13, 2000
    241
    Babylon 5 is released from Warner so you won't have bilingual.
    I doubt a separate "French" version will be released as it's a gift set.
