Can you use VE disc to calibrate your computer monitor?
Discussion in 'Archived Threads 2001-2004' started by Bolivar G, Aug 28, 2002.
  1. Bolivar G
    Bolivar G Second Unit
    Jul 9, 2002
    318
    I got my VE disc in today and calibrated my TV with it.
    I did notice a change, picture does look better.
    I was wondering I can use it on my Computer monitor also? [​IMG] I have a DVD -rom drive, so can play it on my computer.
    My monitor is a 21" Viewsonic P225. Just wondering is this possible or even a good idea? [​IMG] Or there something else used specifically for Computer monitors?
  2. Bolivar G
    Jul 9, 2002
    318
    So no one has any info for me?? or never been tried?
  3. Boka
    Boka Stunt Coordinator
    Jul 29, 2002
    61
    Adobe Photoshop comes with a monitor calibration utility called Adobe Gamma. I don't know if it can be found seperately. It has you go through some of the same basic stuff as the DVD calibration disc. Monitor calibration is definately worth the time, like RPTV's, most monitors are overally contrasty and bright.
  4. Bolivar G
    Jul 9, 2002
    318
    I dont have adobe [​IMG]
    Is there a free trial version avialable??
  5. Geoff H
    Geoff H Stunt Coordinator
    Aug 29, 2002
    65
    If you're doing any serious color/image editing you are better off using a monitor calibration tool and associated software. I used to calibrate by eye using Adobe Gamma but absolutely nothing compares to a dedicated "hockey puck" (suction cups to your screen).
    I wish they had them for TV's!
    Check the one out by ColorVision
    http://www.colorvision.com/home.html
  6. Bill Lucas
    Bill Lucas Supporting Actor
    Mar 20, 1999
    530
    There's a program called Displaymate that is perfect for computer monitors. Many of the HTPC crowd at AVS use it to calibrate their HT displays also.
  7. Bolivar G
    Jul 9, 2002
    318
    That thing looks funky [​IMG]
