Can you run coaxal cables next to speaker wire?
Discussion in 'Archived Threads 2001-2004' started by jason123, Sep 15, 2002.
  1. jason123
    jason123 Agent
    Aug 8, 2002
    37
    I am finishing my basement and know the rule about power lines and coaxial lines 16 inches apart. Is their a problem with running shielded 14 gage speaker wire right next to my coaxial cable line?
  2. Will Orth
    Will Orth Stunt Coordinator
    Sep 14, 2002
    80
    Dont think it will be a problem, long as you have a good shielded coax and not a "LONG" run of wire.
    if you can at least seperate them 6" apart would void any problems.
    Will
  3. Peter Overduin
    Peter Overduin Supporting Actor
    Jun 30, 1997
    776
    No. Coax, speaker wire, tel wire, intercom etc., are all LVT (Low Voltage). You can run LVT wire together, but keep them away from high voltage wiring. It is best if you can run them through conduit, however, if not possible, use shielded cabling as you seem intent on doing. It will be fine.
  4. jason123
    jason123 Agent
    Aug 8, 2002
    37
    THANKS ALL!!!!!!!!!!!!!!!!
  5. Will Orth
    Sep 14, 2002
    80
    you can cross 90^ the wires, but dont run them parallel.
    or as a other member said use conduit and drain the gound on one end.
    Will
