Can you recommend a DVD Player that can!
Discussion in 'Archived Threads 2001-2004' started by Troy B, Mar 7, 2002.
  1. Troy B
    Troy B Auditioning
    Feb 9, 1999
    2
    Play DVD-R/DVD-RW,SVCD,VCD and MP3's?
    Troy
  2. Troy B
    Troy B Auditioning
    Feb 9, 1999
    2
    Thanks.
    Will the pioneer 440 play PAL and NTSC?
  3. Eric Alderson
    Eric Alderson Stunt Coordinator
    Apr 22, 1999
    249
    I think NTSC only. I put in a SVCD in PAL resolution and I got a "rolling" screen.
  4. Jeff Kleist
    Dec 4, 1999
    11,267
    You have to be specific. DO you want a player that CONVERTS PAL to NTSC or do you want a player that will PASS both PAL and NTSC
  5. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    Hey Jeff - I kinda new to having to deal with NTSC/PAL. What's the difference between converting and passing the signals?
    -Dave
  6. Jeff Kleist
    Dec 4, 1999
    11,267
    CONVERT- Takes a PAL signal and makes it into an NTSC one
    so that normal US/Canada TVs can view it
    PASS- Will pass the raw signal through the player, out to a TV w/o changing it at all. You must have a PAL capable TV in order to view it
    In my experience most Pioneer players will PASS PAL, but will not convert
    If you want good PAL/NTSC conversion you want the Malata N996 or the JVC model in the FAQ I wrote in the Regional DVD area.
    Daewoo and APex players, while cheap, have horriffic PAL/NTSC conversion.
  7. Dave F
    May 15, 1999
    2,885
    2
    Thanks for the info, Jeff. I think I'll look into those JVC's...
    -Dave
  8. Brad_V
    Brad_V Second Unit
    Mar 8, 2002
    356
    Daewoo 5700, Apex 5131. $99 and $129, respectively.
