Can you hook both optical and analog audio?
Discussion in 'Beginners, General Questions' started by Rich*s, Mar 25, 2005.
  1. Rich*s
    Rich*s Auditioning
    Mar 24, 2005
    12
    My newbie status will be showing here:
    Can you use both the optical and analog audio out connections at the same time on DVD players, cable boxes, TV's etc.? Or does plugging one type in usually disable the other?
    I am trying to run two audio systems with my home theater: an expensive analog setup and a cheap 5.1 AV system. Can I run them both at the same time?
    If not, do "Y" connectors (analog) work well? I'd love to hear from the purists as well as the practical types.
    Thanks.
  2. Don*A
    Don*A Agent
    Feb 4, 2005
    38
    Yes you can.
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    A "Y" connector on the coaxial-digital output is a no-no. The impedence mis-match could cause reflections/attenuation which will cause audio drop-outs.
    Try to stick with digital if you can. Send optical to one system for music and coaxial-digital to another for movies. When in doubt - use the coaxial-digital connection for the longer run.
    Your real problem will be that your DVD player will have a setup menu that gives you a choice: 2-channel or 5.1 channel. If you setup things for 5.1, you MAY not get all the sounds from a CD/SACD disk through the 2 channel music connection. This means changing the DVD player setup menu when you toggle back and forth.
    But give it a shot. It wont hurt anything to try.
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    32
    Katy, TX
    Wayne
    Rich,
    This topic came up a week or so ago, and it seems the answer is “it depends on your DVD player.” Mine outputs both digital and analog at the same time, and like you I send the analog to a secondary system.
    However, some people responding to the thread confirmed that their players had a menu selection for one or the other, so they couldn’t do both.
    Wayne A. Pflughaupt
