can Velocity Scan be turned off on Samsung?? (1 Viewer)
Eric_M
Can Velocity Scan be turned off on the 32 inch flat screens (TSL3293HF) the way it can be on the Sony Wegas?
ALso I have heard, and poste don a couple other posts that this set may be discontinued, according to BB
David Susilo
go to into the service menu (from OFF position, press: mute-1-8-2-power) go to VML (or VLM, can't remember exactly) and turn it down to around 10.
Samsung's parameter is from 0 to 128. 0 setting WILL make the pictury blurry.
Similar Threads
Brasspineapple
