Can styrofoam panels be used as bass traps, if covered in cloth material?
Discussion in 'Home Theater Projects' started by PaulDA, Aug 15, 2004.
  1. PaulDA
    PaulDA Cinematographer
    Feb 9, 2004
    2,696
    96
    4,110
    St. Hubert, Quebec, Canada
    Paul
    I was in the hardware store insulation section today, pricing batts for my walls when I saw some styrofoam panels, of various thickness, and I wondered if they could be used in a manner similar to, if not as effectively as, rigid fibreglass as bass traps? If so, then what thickness would be best? If not, why not? I understand already that it wouldn't be AS effective as the famous Corning 700 series stuff, but it's hard to find in small quantities and I'm also curious about how styrofoam would work in general. Related to that, I also saw some pieces of material used in attic vents (best I can describe as I don't know what they're called. They're shaped somewhat like Auralex's Versatiles, though much longer and thinner. I wondered if stacking several of them together (glued) might make an effective diffusor or absorber of higher frequencies. Again, I know it wouldn't be as effective as other stuff, but it is inexpensive and I'm curious.
  2. MarkRoberts
    MarkRoberts Stunt Coordinator
    Oct 20, 2002
    167
    I don't know if they can be used as bass traps but I know they can be used as room treatments. Check this site Look in the free journal section at one time you could download issue 1 and 2 what you are looking for is in issue 2. I believe he used owens corning rigid foam panels. Very similar to styrofoam and availible at most home improvment stores. I believe he also mentions diy bass traps of the tube variety.
