Can Sony VPL-HS1 handle a progressive video signal?
Discussion in 'Archived Threads 2001-2004' started by John Vo, Sep 24, 2002.
  1. John Vo
    John Vo Agent
    Dec 8, 2001
    26
    I was wondering if the VPL-HS1 can handle a progressive scan signal. I am currently trying to figure out a component video cable solution but it is a moot point if this projector can't handle the signal. Thank you in advance.
    -John
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    Sony Cineza VPL-HS1 Specs
    Acceptable Video Signals: DTV (480i, 480p, 1080i, 720p) Progressive component; 15K RGB/Component 50/60 Hz system; Y/C Video, Composite video
    Acceptable Computer Signals: RGB: Horizontal 19 to 72 kHz, Vertical: 48 to 92 Hz)
    I'm guessing you have to go through the PJ Multi connector. What connector(s) does the SIC-HS10 Signal Interface Cable Multi-V/L/R have?
  3. John Vo
    John Vo Agent
    Dec 8, 2001
    26
    Ahh good. I see that it can handle 480p signals. I was told otherwise. Right now, the SIC-HS10 doesn not have component cables but the SIC-HS40 I just ordered does.
    The problem I have is that the hs40 is only 5 meters long and I need a 7 meter cable. Does anyone know of a good RCA connector that will allow me to connect two component cables together?
    Thanks in advance,
