Can someone please explain the whole "anamorphic" thing?
Discussion in 'Archived Threads 2001-2004' started by Thomas_Berg, Oct 16, 2001.
  1. Thomas_Berg
    Thomas_Berg Screenwriter
    Feb 28, 2001
    1,422
    Dallas
    Thomas
    i know about TVs that can do the anamorphic "squeeze." it basically stretches the image to fit the 4:3 ratio of a normal TV. what i don't understand is what "anamorphic encoded" DVDs are. can someone explain all this please?
    -Thomas
    My HT
  2. Jason Merrick
    Jason Merrick Supporting Actor
    Mar 2, 2000
    696
    110
    Simi Valley, CA (Los Angeles)
    Jason Merrick
    Thomas,
    Anamorphic DVD's are designed to display correctly on a 16:9 formatted screen. When you play an anamorphic dvd on a standard 4:3 set, your dvd player converts the image by basically removing 1 out of every 3 (or is it 4?) lines of resolution so that the image will fit properly on your 4:3 tv. On 4:3 sets capable of performing the anamorphic squeeze, the vertical size of the picture is literally squeezed down to force more lines of resolution into a 16:9 space, when your dvd player is set (fooled) by telling it you have a 16:9 tv, it outputs the full resolution filling the space correctly.
    Their are 2 main benefits that I personally have noticed with this:
    1) No more jaggies from the dvd player's downconversion.
    2) A very noticeable reduction in the horizontal scan lines that used to be visible running across my screen.
    I am not a very good writer as you can now tell, so if this doesn't make sense, or more likely, my grasp of the facts are completely off base, I am sure someone will post a better and more accurate definition for you. [​IMG]
    [​IMG]
  3. PaulKH
    PaulKH Second Unit
    Oct 3, 2001
    413
  4. SteveBjr
    SteveBjr Stunt Coordinator
    Aug 7, 2001
    196
