Anthony_I
- Sep 9, 2003
What really is the point of it? to have a constant added frequency when your speaker is working?
And how do you know what frequency you want it tuned to.
If the manufacturer suggest a port length and you figure out what its tuned to, could you use 2 or more ports that were all tuned to equal the suggested frequency? what problems could come of not tuning it/using the port length suggested by the company?
Also if i use a ported box and use the sizes suggested by the company bassbox shows my excursion far exceeding its limits.
Thank you
Thank you
