Can someone please explain DVE's color test to me, I don't understand it...
Discussion in 'Displays' started by kurt_fire, Jun 17, 2004.
  1. kurt_fire
    kurt_fire Stunt Coordinator
    Dec 29, 2002
    183
    It says to look through the blue filter and adjust the color until what..........happens?? Also, the tint test is the same way, i am lost during that part too.
  2. RudyN
    RudyN Supporting Actor
    Sep 12, 2002
    586
    Mundelein, IL
    Rudy Nunez
    You adjust the color and tint until all the blues match.
  3. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    I think it goes this way: The test pattern to be used has the usual seven wide upright color bars and also some blue and pink squares below them. Through the blue filter you see four vertical bars each with a "larger top half" and a "smaller bottom half". You adjust the color control so the top halves match the respective bottom halves. You adjust the tint control so all four bars seen through the blue filter match.
    Video hints:
