Tony Meconiates
- Jan 21, 2002
Also, I was looking at speaker cable and what is the difference between spade and banana?
What do paradigm reference speakers use?
Paradigm Ref Speakers use 2 sets of 5-way binding posts so you can use either bananas or spades. However, Paradigm uses larger than normal posts, so if you want to use spades, you'll have to specify 1/4 inch or "Large" spades.
Obviously if you're going to bi-wire the Paradigms, be sure and remove the metal jumper bar that connects the two sets of binding posts together prior to bi-wiring.
