Can someone model Treo SS drivers for me? (1 Viewer)
GabeT
Grip
I have two of the 15" and am going to build an enclosure mostly for music but some home theater (So I want to retain as much low end as possible). The specs can be found here:
http://treoonline.com/ssi.html
They are the SSi 15.44
I really appreciate any help! :)
Shawn Keeler
I am also using Treo woofer's for my home theater set-up. Keeler Theatre Can't beat them, they are bullet proof. Gabe, what was your question again? I am in touch with some of the Treo factory personel, and could probably give you some help.
Jason Dalton
Maybe someone else can verify this, but to me these look like they are going to be tough to use for home theater with a decent amount of EQ.
On a side note, the spec sheets on their website are very well done. Very accessible.
GabeT
Grip
I modeled them myself and they seemed to have very good extension when put in a 4 cu ft box tuned to mid 20's. They seemed to do better than the Tempest between 20-35 hz.. but that could be from an error in my modeling :b
MBH
