Can someone help me! (1 Viewer)
JoelM
I have a Denon2802 and it has only one speaker connection for the back surrounds. If I bought a really nice sterio amp(need suggestions 8ohm 200watt) can I use the 2 empty speaker connections to use for the back surrounds? If yes then how? I'm sort of new at this. Here is what I have if it helps. Thanks a bunch!!!
(1)Denon2802
(2)Swan Diva 6.1
(1)Swan Diva c3
(4)Swan Diva r3
(1)Sampson amp1000
(2)SVS25-31CS+
peter_anderson
if the 2802 has two channels of pre-amp output for the back surrounds, then just connect those to the CD or Aux input of the two channel amp/receiver and plug the back surround speakers into the 2 channel amp.
WavyJawn
