Can someone explain what SUB CROSSOVER MEANS?
Discussion in 'Archived Threads 2001-2004' started by scott_tinari, Aug 4, 2001.
  1. scott_tinari
    scott_tinari Stunt Coordinator
    Feb 10, 2001
    121
    I have a Onkyo Integra 5.2 receiver and the energy take 5 speakers with the 8" sub. How do I set my crossover on my sub to 80hz or whatever. The dials on the front of the sub suck, the dials are not labeled. One dial is for the crossover I think and the other dial is to louden the sub. Can someone explain. Thanks
  2. Brian Fellmeth
    Jul 30, 2000
    789
    The crossover on the sub is there to use when it is fed a full range signal. It prevents the sub from trying to reproduce the higher frequencies. It is surperflous for you since you feed it a signal from a HT receiver that is already stripped of high frequencies. It shouldn't be set to anything- it should be defeated. I believe this is easy with your Energy. Use the jack labeled "external xover". This will render both knobs inoperative, and the sub is now controlled by your reciever.
