SteveW
- Oct 29, 2003
I currently have my speakers running full range set to small. With my new set-up I want the front l/r to be have a crossover point above where the sub goes below. Do I accomplish this by using the speaker level inputs on the sub. If so I am a little confused. The sub I am getting is the TN-1220HO with 250 watt amp. On the specifications it says that this amp has line level low pass but not line level high pass. I guess I'm a little confused on the line level low pass and high pass. Can someone clear this up for me.
Also are there different settings on new receivers that allow crossover points to be set. My older Onkyo does not. But I am currently looking at either the Onkyo TX-SR601 or the Denon AVR-1804. I don't know if they do
