Can my system play at reference levels?
Discussion in 'Speakers' started by Ryan_McCormick, Aug 7, 2003.
  1. Ryan_McCormick
    Jul 4, 2002
    42
    So what does it take to play at reference levels? I currently own a Kenwood VR-605, 4 Polk RTi28's for mains and surrounds, CSi30 Center, and a Velo CHT-15. The amp is rated at 100 wpc, but we all know its not pushing more than around 30 wpc with all channels driven.
    So what do you guys think, can i play at or close to reference levels? I have always been curious as to what it really takes.
    P.S. Can you damage the polk silk/polymer tweeter by brushing your finger across it? I touched one of mine the other day and it dipped in and rolled right back out. I was curious if any instant damage can be done.
  2. Steve_D
    Steve_D Second Unit
    Nov 28, 1999
    299
    Doubtful if you can play cleanly at Ref levels in anything other than a small room.
    If you damaged the tweeter...you would hear it.
  3. Ryan_McCormick
    Jul 4, 2002
    42
    So you think i could damage the tweeters at reference level then? My room is 13x20 by the way.
