Can I use this type of cable with a powered Sub?
Discussion in 'Archived Threads 2001-2004' started by Rob Robinson, Oct 8, 2001.
  1. Rob Robinson
    Rob Robinson Second Unit
    Aug 8, 2001
    294
    http://www.radioshack.com/searchsku.asp?find=42-2480
    it's $10 for 50 feet.
    I need a 40 foot run to get this around a double doorway, and the cheapest "real" sub cable I could get built was $90 (!!?).
    If this is no good, does anyone else have any suggestions about the best way to cheaply get a 40 foot run.
    The only other option I would have would be to run it under a rug, whicvh would be ok, except there is agap of about a foot between both the rug and the rack and te rug and the couch, so it would have to be taped down and ugly.
  2. stephen abbot
    Sep 28, 1999
    45
    I suspect from looking at the cable in the picture that this is a parallel twin type cable rather than a shielded cable. Whilst this type of cable is ideal for a low impedance, high level speaker interconnect it is not appropriate for a line level feed to a sub.
    I recommend that you find a RG59 orRG6 cable with RCA connectors at each end, or purhaps with F connectors and a couple of F-RCA adaptors. This would be a more correct shielded type of cable suitable for a line level interconnect.
    Cheers
    Stephen.
  3. Rob Robinson
    Aug 8, 2001
    294
    thanks -
    i'm just having trouble finding this. I can find the cables, without connectors. But I can't find any reasonably priced pre-built ones.
    got a link perhaps?
  4. Steve T
    Steve T Stunt Coordinator
    Oct 12, 2000
    86
    Rob,
    I would not recommend the cable you specified, although it may work. I suggest a cable with good shielding for use with your sub. When I originally placed my sub behind a couch I used a 50' RG6 cable from Radio Shack, and bought a couple of "F" to RCA converter connectors. This would provide you with a good quality subwoofer cable.
    http://www.radioshack.com/product.asp?catalog%5Fn ame=CTLG&category%5Fname=CTLG%5F002%5F004%5F005%5F000&product%5Fid=15%2D1568
    http://www.radioshack.com/product.asp?catalog%5Fn ame=CTLG&category%5Fname=CTLG%5F005%5F003%5F001%5F001&product%5Fid=278%2D290
    [Edited last by Steve T on October 08, 2001 at 03:57 PM]
  5. Rob Robinson
    Aug 8, 2001
    294
    Steve- Perfect!!!
    though I was this close to ordering a 1000 foot spool of Belden from pasrtsexpress...it was on sale for $37. Know idea how to go about assembling those. It seems like with canare you can just buy the kit and it does the work, but the belden looks a bit more intense, with soldering and stripping.
    I think the radio shack deal you suggested will work. it's also what chris white reccomended via email, but i couldn't find these parts.
    god, this place rules.
  6. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I have used the Radio Shack RG6 coax and the "F-to-RCA" adapters. But I just bought some nice crimp-on RCA plugs for coax from Parts Express for about $2.30
    If you like tools, I strongly suggest getting the $17 crimp-frame handle from Parts Express, the RG6 dies and some of the crimp-on RCA plugs.
    Should set you back about $30, but you will have a great tool in your box for all your future CATV coax needs.
    (Then you can buy the nice Canare dies for $60, and some bulk Canare cable and make your own video & audio cables.) [​IMG]
    Good Luck.
